TJ
BE 6 pack 2
I purchased a BE6 pack 2 recently and went on a 250km drive and when i came back the battery was 18% and i left it with full charge. Company claimed it to be 460.
Comments (16)
@Ferrarirules Vapi to surat and back, i have maintained a 80-100kmph speed and my regen was at L2 and i drove the car decently.
How long since you purchased the vehicle? Have you done the cell balancing by doing doing deep discharge and then 100% charge using AC charger? This will help us find a solution.
@Suhail Gulati Purucased the vehicle on 19th october sorry i didn't get you, can you please explain in detail
@TJ Purchased*
@TJ After buying the car,you need to take it to 25-30% and do a 100% charge atleast 2-3 times. Then once you need to discharge till 10% and AC chargetil100% as well for cell balancing.
@Suhail Gulati In time you can follow 100-20-80-20-100 pattern on SoC. But do charge till 100 from 20-30% initially on AC charger.
@Suhail Gulati I have done recharging from 10 to 20 percent thrice on my home charger, you mean once or twice i should go to the charging station and charge while it is at 10 percent or below?
@TJ Home charging is fine. You charged till 100%? Post 100% you can keep the charger connected for sometime for small currents to pass through and balance the cells.
@Suhail Gulati I have done that too but it disconnects as soon as it reaches 100 percent.
@TJ You should take it to the service center once and ask them if there are any updates which are pending on your EV's BMS. Get it checked. Do one more trip and see if the resukts are similar.
@Suhail Gulati Yes sure Thanl you✌️
It shouldn't be the case. I have the XEV pack 2, 59 and I went from Delhi to Ludhiana with 20% to spare on the charge - distance of 350 KMs. Also had the regen at L1 and had the driver driving it who was not the most efficient driver. I definitely think you need to get the battery checked
@ankitgoel13 I called them for the same, they said let the car reach 1st 1000km and range will be increased. I will wait for another 1000 now
First of all, Vapi to Surat is not a flat terrain .. 80-100 KMPH does used more power .. Many other factors like total occuants and the luggage in the vehicle .. Ambient temperature .. Usage of Air Conditioning levels .. Drag .. and even many more decrease the efficiency .. I would also recommend you doing a 8-100% charge cycle to calibrate the SoC ..
@Asheesh Its a flat terrain only, we were three with no luggage and ac was on fan 2 with 18°C and as i said i didnt drag it.
Can you please share the route, the speed that you kept for this drive?
